Road Grabber
- 6:20 AM
- Apr 14, 2020
- Sarasota Florida/NY State
I think I might have a distributor problem. I have tracked down other vacuum leaks, switched to a restored carb and still have some hesitation/lack of response.
I saw another ;post that ended up with a vacuum advance problem. I am thinking maybe I have a vacuum advance leak problem.
I'd like to remove the vacuum advance from the system and go mechanical advance. Is there a way to make a vacuum advance distributor into mechanical advance?
I have a mechanical advance setup in another car. Had the distributor setup for initial 14 advance and total 34? It works great. I am thinking of doing to the same thing by changing the dual point I have now into a mechanical advance setup.
Any thoughts? Ways to check the existing distributor?
I used to know where to take the distributors to have them diagnosed and checked but those guys are no longer around.
Thank you
Thank you
