- 10:45 AM
- Aug 29, 2019
- Jarvis, Ontario
I just drilled it out carefully using increasing sizes of bits and finally an easy out. The trick is getting the first hole straight and centered.
That car is going to be a fun driver. Are you going to try to buff out the paint or leave it with some patina?
I found a drill guide, but I'm going to try to weld a nut to it first. A guy that does a lot of them for his work and in his home garage looked at it yesterday and said I may be able to get it out that way. If not, and I screw it up, these heads are cheap and easy to find.I just drilled it out carefully using increasing sizes of bits and finally an easy out. The trick is getting the first hole straight and centered.
Sounds like it. Thank you. I will try my best to get it out.It may take a few tries, the heat and cool cycles will help break it loose.
I had to do about 8, in the vehicle, on a 68 caddy 472.
That was a true nightmare.
I did not bother looking, but now that you've asked I will go out and look. I'll post up the number. I am sure they are the original for the 66 361.Are those to original closed chamber 516's? Hard to tell from the pics due to the carbon build up
Yep!Are those to original closed chamber 516's? Hard to tell from the pics due to the carbon build up
Keep trying to pound the stud with weld/heat and then work your way out to the nutOk, so gave up for the day and came inside. I need to snap a pic of all the nuts I've used that just twisted off. Seems I can't get weld penetration into the stud for some reason. I moved onto the other broken stud and after 3 or 4 tries it came out. That fueled my fire to go back to the first stud. 5 or 6 more tries and no movement. Going to ask a few friends for some input/encouragement.View attachment 1327304
Perfect. After a while a guy starts looking for better nuts that weld nicer too lol.After countless times, I remembered that old adage, the definition of insanity is doing the same thing over and over and expecting different results. With that in mind, I called my neighbor down the street and discussed some things I had been bouncing around. One of them was heating up the stud. The reasoning behind this was it appeared the weld was not sticking to the stud, which made me think all that iron around it was dissipating the heat, not allowing the weld to properly bond to the stud. I dug out my torches and put the weld tip on it and heated the stud up. Then, I welded directly to the stud with no nut, then put a nut on it and welded to that. It actually moved about 1/2 turn and then broke off. Progress! I had to grind some of the weld off the cast iron and then heated again and welded the nut to the stud and it moved again before it broke! Then, my neighbor, Mike, swung by and we double teamed it. I put all my weld gear on and he used the torch to heat the stud and then I used the magnet to place the nut on and welded it while everything was still hot. I got about 1 full turn before the nut broke off. Success! We did that 2 more times and then, it came all the way out! Yay! Finally!
Tomorrow is Mopar Nats, tomorrow night is Street Car Takeover at the local track, then Saturday I think I can start putting this thing back together. I have a head gasket on order, but if I spot one at the nats, I'm picking it up so I can get this back together. Can't wait! I'll finally hear it with no exhaust leaks for the first time!
Pics of all the nuts I used, lol. I think I'm getting low. Lol. And the bastard himself, finally outed.
View attachment 1327429View attachment 1327430View attachment 1327431View attachment 1327432View attachment 1327433
Damn, yes I am motivated now. I want to drive it so badly.Some motivation for you.
Mine last weekend.
Took it to a local cars and coffee yesterday. And the drive home was mucho excellent.
