I guess if depends if you understand the fundamental differences between resistance, inductive reactance and capacitive reactance ......if you don't understand....that's OK.....and if you do.....great.....enquiring minds want to know about many things ..... or not.....your choice.....So basically just another one of your long drawn out responses using technical descriptive terms to answer a question no one asked ?
My original comment was correct. Pick it apart if you want. Using 1.5ohm ballast and 1.5 coil is going to give more resistance than he wants and lower the voltage. PLAIN and SIMPLE.
I was writing to answer his question and help problem solve his situation . Not a response to try and show off my knowledge and be graded by an electronic engineer.
Also forgot to mention ( sorry this is a pretty old post brought back from the dead. )Hey C1968,.... Your before & after Volt & Current measurements are Very interesting !!! Don't ya just love it when the simple numbers logic Doesn't add up ?? ....The before measurement of 4.5 amps @ 13.4 volt battery would indicate a reasonable Total 3.0 ohms Resistance circuit, yours being 1.5 ohm coil & 1.5 ohm ballast resistor.....The HEI Module without resistor Should pull More amps but it's Low rpm Auto dwell Reduction logic is likely Messing with your Indicated Current amps by causing your meter to read a Shortened dwell time Averaged reading ....The HEI module usually self current limits at 4.5 amps anyway but you likely need a fast scope to see the Real dwell pulsed current amperage.....The HEI tends to protect most any stock type coil...
A curiosity question......EXACTLY WHY are ignition components INTENTIONALLY mis-matched?? These components, coil, ballast resistor, ECU are interchangeably mixmatched for what intention???? ......it seems as if the hope of more horsepower is the quest....without regards to the consequences. Case in point, using the GM HEI module, an Ecore coil, and no ballast resistor gains exactly what, compared to the vehicle's (OEM) standard ignition system......a graph of horsepower/torque produced vs RPM @ various loads (dyno runs) to show the exact differences.....or time trial numbers....that show the ACTUAL differences not seat of the pants guesstimates.......In my opinion..
The biggest issue about ignition systems, is the mismatch that can happen when different brand OE and aftermarket components are mixed together. My preference is to stick with 1 brand and their specific recommendations for the distributor, ECU, coil and ballast resistor... Intermixing different source ignition components will often result in the complaints posted on this forum frequently..
Just my $0.02...
Good question...A curiosity question......EXACTLY WHY are ignition components INTENTIONALLY mis-matched?? These components, coil, ballast resistor, ECU are interchangeably mixmatched for what intention???? ......it seems as if the hope of more horsepower is the quest....without regards to the consequences. Case in point, using the GM HEI module, an Ecore coil, and no ballast resistor gains exactly what, compared to the vehicle's (OEM) standard ignition system......a graph of horsepower/torque produced vs RPM @ various loads (dyno runs) to show the exact differences.....or time trial numbers....that show the ACTUAL differences not seat of the pants guesstimates.......
BOB RENTON
