440 identification
Is this car not in your posession?? I thought you were going to look and tell us. I say the pad is there.... and I'm sticking to that..
It is my car but at its storage facility..I can check early next week
Its a 1967 440 HP based on the pictures you have provided so far.
The true tell is the close up picture of the engine ID pad that shows - year / size / build date / shift / any special stamps
I will definitely be looking when I see the car again...and will provide pictures...Thanks to all
Spark plug wire bracket is held on by the 3rd bolt. Pad is definitely there.. you on a phone..
Sparkplug wire bracket is held on by the drivers side water neck bolt, but it positions the sparkplug wire in the way of the pad.
Looks like it may be a correct carb as I can see the 3-step metering rod, raised caps and the tag is correct.
As long as he can read the stamp or knows the history. My 69 RR had a 413 in it but the 2nd owner after me had it for sale saying that it was a 440.
I can't see the pad :poke:
Pad ? Pad ? What's this "pad" everyone's talking about ?
Correct Engine number on pad on front drivers side in front of
manifold cats into the block would have this sequence stanped into it:
C440 HP or
Hp2
Side of block would have Julian Date
of around 6/xx/66 to 6/xx/67
Restoration guys w have better details = I am just a racer but
we had two new 67 GTX's My dad took delivery 11/5/66 and we had
only seen then in mags before that!
This engine looks perfectly original OEM to me.
the only real way to tell is check the casting #'s i have seen the web stamped wrong or lefted blank all rb's will have a web on the top for a stamp
  • Mopar Engine Block Casting Numbers.pdf
You might try looking at the side of the block below the head and above the freeze plugs. (This photo is upside down)
Finally got the time to get to the car and here is what is seen on the pad
Let's see if I decipher the numbers correctly
C=1967
440 engine
Jan 4 build date
HP= High Perfomance
