440gtx1967
Just wanting some opinions regarding this particular carb, for use as sub for the stock carb on my 67 440 GTX...Thanks
Proform Street Series, Vacuum Secondary
Fits: 750 cfm, 4-Barrel, Dual Inlet, Dichromate,
Carburetor, Gasoline, Proform Street Series, Universal, 750 cfm, 4-Barrel, Dual Inlet, Dichromate, Each
CFM: 750
Fuel: Gasoline
New or Remanufactured: New
Number of Barrels: 4
Carburetor Flange: Square bore
Choke: Electric
Secondary Type: Vacuum
Fuel Inlet: Dual
Carburetor Finish: Dichromate
Ford Kickdown: No
Booster Type: Down-leg
Quantity: Sold individually.
These Proform Street series carburetors are perfectly matched for your everyday driver. They are hand-assembled using Proform's high-flow, lightweight aluminum carburetor main body that has been CNC-machined. They use changeable screw-in air and high-speed bleeds and include high performance down-leg boosters. Attached to the main body is Proform's billet aluminum throttle base plate, which features adjustable power valve blowout protection, a corrosion-resistant anodized finish, button Torx head screws, and easy access to secondary idle airflow adjustment. The Proform Street series carburetors use billet aluminum metering blocks with changeable idle feed restrictors, non-stick gaskets and four corner idle system on mechanical secondary carburetors. The final components of the carburetors are the fuel bowls. They are manufactured from lightweight die-cast aluminum and feature fuel level sight windows, an externally adjustable needle and seat, dual-feed fuel inlets, and a notched secondary float. Finally, there is a cost-conscious carburetor that's built for the street. Get one of these Proform Street series carburetors and start performing better today.
CFM: 750
Fuel: Gasoline
Choke: Electric
Fuel Inlet: Dual
Ford Kickdown: No
