I moved it to the fender apron near the firewall.
It is accessible but not in the way of anything.
I can see your point, I wouldn’t wanna damage my paint either. I’m thinking of selling my Passion 5 speed and getting a TKX kit from Silver Sport Transmission.I wanted to use DOT 5 fluid in it for the reduced risk of paint damage but the man at Silver Sport stated that DOT 4 is the only fluid approved to use.
It sure could, but The Right Stuff really bonds good and is a bugger to get things apart and cleaned up if something has to come back apart compared to regular black rtv.Nice work KD.
Seems like many of you like that Right Stuff. Can anyone tell me if it would be suitable to replace the typical Permatex 2 black that is commonly used to smear on both sides of a water pump gasket or is the Right Stuff more to take the place of a gasket?
Dumb question but did you check the ports on the booster to make sure there were no plastic plugs inside ? Those plugs are easy to miss, don’t ask how I know. I am not being a wise a** here and please don’t take me the wrong way.The power steering pump swap is complete. The pump in the car now is the one I’ve had since 2006 or so. It has worked well since I put it in.
Steering boost works like it should.
Hydroboost is dead. No boost. No assist at all. Stopping the car feels like before, similar to a power brake car with the engine off. Very disappointing. I drove around the back yard at low speeds to see if it would start to build up pressure but I’m getting nothing.
I don’t know what I did wrong. The hydraulic lines are tight and not leaking. They are connected to the right ports. Maybe the HB unit itself is bad?
At least,I can drive the car at low speeds. The car lift bay has been occupied for over 5 months while the maintenance on the other cars here have been delayed.
I’m going to let it stew for a little bit before I make a decision.
I will admit though that my inclination is to pull this unit and install the manual master cylinder that I was originally going to use. If the pedal effort seems too high, I may pull the brake pedal and drill a new hole above the original one to increase leverage.
View attachment 1368864View attachment 1368865
Could it be just a bad booster?
When I am frustrated, ALL options are considered.Dumb question but did you check the ports on the booster to make sure there were no plastic plugs inside ? Those plugs are easy to miss, don’t ask how I know. I am not being a wise a** here and please don’t take me the wrong way.
Wait, you mean you've never had the pleasure of owning one of these beasts with manual drum brakes before?I've read that cars as heavy as mine are hard to stop with a manual master cylinder. That may be true.
This car had 4 wheel 10" non power drums when I bought it. It actually stopped okay. Not great but okay.Wait, you mean you've never had the pleasure of owning one of these beasts with manual drum brakes before?
Hell, I've never owned one that had power brakes.![]()
