pedal2themetal
Hi,
Oh 75 Fury 318
Car was running like always.. I fuel up, go 1/2 a block to store parking lot.. start it when leaving and it runs like **** Won't idle missing and such make it home buy driving in second .. found a spark plug wire lose .. pushed it back on still won't run.. So I replaced all the wires .. ran ok cold but when choke went off it went south again .. had to open the mixture screw's about 1/4 turn and step up the idle still not right messed with all my vacuum plugs no change. Don't hear any vacuum leaks
Sence it went bad right after getting fuel I fuggured it was the fuel.. (since I use premium I figgured it sets a lot in the tanks in the ground ) So I got some HEAT and put in a bottle, took a 40 minunet drive on the freeway 70+mph.. seamed to run Ok at high way speed but Still not idling right ..
Well I have to run all the fuel out and refill it with good gas to solve this issue??
Any advice is accepted
Thank you take care
tim
Oh 75 Fury 318
Thank you take care
tim
