1962 header info..
icetech
10:49 PM
Macomb Mi
So.. i did enough reading to get confused :) I am switching my 62 poly to a LA and hadn't considered exhaust til now (still early, just planning ahead.. haven't found a engine yet) But i decided to look for headers.. i have read that basically any b-body headers even into the 70's would fit.. then i read that i think 62-65 the engine is moved forward and the later headers wont work? Basically just looking for some clarification.. The 62 has the flat motor mounts but i don't think they will be an issue. This is just a beater/driver and TTI/Dougs are stupid expensive to me. Hoping someone might be able to share what actually works?
I saw Just mopar joe used shorties on his.. but it's a 65 and i'm not sure on the changes as far as headers go..
P.S. i could still end up with a big block (if one falls in my lap) but am mainly thinking small block so i can keep the pushbutton..
I put a 70 LA 318 and 904 in my 63. Summit and Jegs have budget headers coated and un-coated.
I bought the Summit un-coated (painted) #SUM-G9040 less than $250. Ceramic coated #SUM-G9140 less than $400.
Fit fine lots of room in a B body.I now wished I got Ceramic.You do have to remove the center link and pass it thru the driver side header.
Photos
Thanks much! I didn't know if the 62 would be any different due to the older type motor mounts but should be fine.. And yeah.. knew about the center link, i have never run a small block before but when i was a kid my friends had them and that center link issue seemed like the end of the world back then, now it's just another 10 mins :)
Found a 69 318 near me for $250.. might snatch that.. Really wanna try doing a 318/390 stroker.. but that's for another year
P.S. i had seen those headers on their site but they listed them for trucks, didn't realize they were b-body also :)
I bought the Summit un-coated (painted) #SUM-G9042 less than $250. Ceramic coated #SUM-G9140 less than $400.
Photos
I screwed up on #G9042 is not correct. #G9040 is for a B body
I'll change it in post #2
Kind of wondering if those are the same as Flowtech 13100FLT.. I know summit relabels a lot of stuff to resell as their own. Only reason i wonder is... although i hate amazon.. parts are free from them (5% back on business credit card adds up fast) and free is always a bit better :)
FLowtech Link
Pretty much any header should be above summits' free shipping cost threshold.
The 62-65 have the motor in a different spot than later B"s, but nobody has ever said what the problem area is that makes later headers NOT fit.
I would try jegs or Summit brand full length headers, uncoated, till I know they fit, or after "modifications" (read:big hammer) have been made. Then, either coat or paint.
Shorties should be easier, but in a 62, I have no idea if they would fit.
In my 64, with 383 and hooker competition, the big issue is where the pitman arm and idler arm swing. Had to beat a few pipes to about half squashed. 440 might be a bit better from being taller.
With a 440 and the big tti's, no problems with fitment at all.
I honestly don't think i have ever had a set of headers that didn't need "Adjustment" :)
I think the fit problem is with header for big blocks. I once tried to put a set of early B Body headers on my 67 Coronet. The right side tubes pushed back into the firewall so far that it would take a sledge hammer "massage" to make them fit.
