Once I had the top of the engine stripped I thought I was home free but the previous owner must have RTV’d the heck out of this intake and I haven’t been able to budge it. The gasket at the front China wall was easy to separate but the side gaskets are like a rock. A sharpened putty knife and a set of Craftsman gasket scrapers won’t hardly dent it. I put the bottom coil mount bolt in and tried using that as a lever point with a combination crowbar/nail puller but it won’t budge It. Pulled the valve cover on one side to try to get into the gasket with something to separate it but can‘t make a dent in it and there aren’t any good prying points. Scraped the paint off the outer edge of the gasket and soaked it with Kroil which I’ve heard softens gaskets but I doubt it can penetrate deep enough between the intake ports to help much. Not wide enough to get anything in strong enough to pry with.
Also tried a heat gun on the areas of the intake between the runners.
Damn Bubba strikes again. Anyone have any ideas?
