Easternair
Yes I used the ceramic shoes in the front and the regular less expensive ones in the rear since the majority of the braking falls on the front.
I had this issue until I saw this thread. I posted some pics a page or two back. No matter what I did they clunked, grabbed etc. Ran to O'Reilly's and looked at a new set side by side with the old. Felt they were GTG. Lining was way off on the old ones. So far so good. Bad thing is they are bonded but, will get me through this summer. Everything is getting an upgrade over winterI am struggling with the same problem. NEW Bosch riveted shoes. Very short non centered lining on primary. The areas on the shoe plate that should contact the pads on backing plate are in wrong locations. The brake activates when rolling tire forward and releases when rolling tire backwards (car on stands). DO NOT BUY THESE CHEAP BOSCH BRAKES FROM ROCK AUTO. I was fooled by the name. Will report back when I get better shoes on the car - 64 sport fury.
| DYNAMIC FRICTION | 1903058100 |
Take your old shoes and have them relined.Well the plot thickens. Stopped by an old timey part store and looked at their old catalogs. The old catalogs show a #155 shoe for our 64 with 10" brakes. Later catalogs show a 169. SOME 169s appear to have the contact points in the right location and some do NOT. I WILL find a set of shoes that mate to these backing plates and I will post what I found.
Think like a drag racer, no engine running unless someone is in the drivers seat.You'll be amazed at what it takes to get a guy with an automatic to start using the parking brake !!!![]()
Yeah I know. Its kind of a hack, I saved all the parts. Maybe if I get ambitious I will replace all of the cables but I don't like working underneath vehicles anymore.You'll be amazed at what it takes to get a guy with an automatic to start using the parking brake !!!![]()
I figured they were shot anyway. Didn't want to leave any loose metal parts in the drum.Sad you cut them for no reason. Next time just disconnect and remove the lever between the cable and shoes and leave all the cables alone.
I’m a bit confused on the mechanism that causes the lock up? What is meant by self generate? Are you saying the adjusters are tightening the shoes moving forward?If you have drum brakes and have serviced the brakes and replaced many parts including the brake shoes and now your drum brakes drag and lock up when turning in forward direction but release when turning in the opposite direction the problem are your brand new brake shoes! The primary shoe has the shorter brake lining material and many new brake shoes are coming with that front lining not centered but much lower on the brake shoe (see pic). Many reputable companies are putting out these brake shoes probably because they are all being imported from the same factory in China. And therefore have the front lining off center. After reading many forums at 'b-bodiesonly' and having many well intentioned participants giving out the same wrong information and changing many parts including wheel cylinders..master cylinder..even the power brake booster and trying out multiple return spring combinations thinking that they weren't strong enough to pull the shoes back, the problem would not go away. The brakes continued to self generate when rotated in the forward direction and lock up but functioned normally in the reverse direction. The solution is to look at the photos closely and replace your brake shoes with ones that have the lining material in the center. (see 2nd and 3rd pics). The problem is that the top edge of the off centered lining is getting caught on the brake drum when the brakes are applied and causing the shoes to self generate which is clearly visible by watching the star adjuster move aft as the drum catches the leading edge of the front shoe and starts to self generate causing the wheel to lock up. Change the brake shoes with ones that the linings are centered and your problem is solved.
View attachment 1240493 View attachment 1240494 View attachment 1240495
We called it by its real name, emergency brake, and I’ve used it as such with the single master cylinder cars. In 55 years I’ve never used but one “to park a car” I did drive a 1960 Dodge that had no ‘park’ with a push buttons auto trans, the ‘emergency’ brake WAS used when at rest.You'll be amazed at what it takes to get a guy with an automatic to start using the parking brake !!!![]()
