69 Sleeper Bee
Also this picture bothers me because there should be all Pressure treated wood against any CMU because of condensation
It is DOUBLED over both Windows - 2"X 10" Rim JoistsOk I am on my computer now and can see the pictures better. The rim joist looks like a 2''x 10'' if that is what your floor joists are and is probably just a single ( I would have doubled it over the span of both windows ) but it is supported between the windows so the floor joists are probably not the problem.
What everyone thinks are headers are there only to nail the window and plywood to and the sheet rock on the inside so not structural but they have warped bad for some reason. Could be crappy wood or a moisture over time problem.
Edit: Or they could have been that way all along but covered by the paneling, just a cheap way to frame IMHO
I mean pictures of those windows and how they were trimmed from the inside the way it was when you bought the house.Those windows and all framing where installed from new construction in the year 2000 when we purchased the house
I wanted to install cedar tongue and groove or car siding
Thank You !!!If you have two rim joists supporting over the windows then your fine provided that they are well nailed together and this makes a flush header/beam . That is standard framing practice perfectly good to code which allows for more window space. (That is 44yrs of construction talking)
Tell that to construction companies in Hawaii.Also, you do not want pressure treated lumber for framing. There should be vapor barrier between the concrete and the wood.
We also do solid headers over any openings here in Florida but for the hurricanes even if there is a second floor system above framed like the OP’s house is.Tell that to construction companies in Hawaii.
44 years of construction....
All throughout my career, I ran into guys doing stuff wrong while saying "I've always done it this way".
Here in earthquake and fire country, you do not omit headers over openings.
The "exact same thing" by definition means identical in every way.The doubling of a rim joist is the exact same thing as a header just in a different location.
You can also keep your insults to yourself.
accept maybe a steel beam..Nothing beats a solid chunk of wood for strength.
LOLHawaii
California
Hurricanes
Earthquakes
Hang on
Need to head outside and check on my Siberian Huskies
Yep , still in WI
