Mally69
Omay so i have this 400 big block. Im pretty on top with all the numbers on everything. But this is the first block i ever got that has an iron cross stamped on it. So i pretty much know this is a 76 400. And so what i did is i sae that and i popped a main cap and a rod cap and looked at the bearings.
Here are the pix. I shall assume this means they are 20 under so the crank was cut extra when manufactured. Im positive thats what this means but Just wanted to see what you guys thought.. here is the block ID as well as a main and rod bearing.. eother way makes no diff to me, itll be getting a stroker crank anyways so , this is irrelevant..
