- 3:16 AM
- Apr 13, 2012
- Granite Bay CA
No, I haven't. I am considering it though.Did you try a bendix dual diaphragm brake booster yet?
The warning light is pointless, in my opinion. At the point where it would light up, any intelligent person would already know due to a low pedal anyway.I agree it will need more pressure, a front brake hold off valve as way to get the rears on slightly ahead of the fronts to transfer weight, and once it will skid either an adjustable proportioning valve. How to get the pressure up is the hard part. I would not gut or eliminate the warning light permanently on a street driven car for legal reasons if anything ever would happen.
Thank you.I am saying if you crash and someone gets hurt it could be a legal issue.
I already gutted one. I have not swapped it in though.Rather than gutting the valve replace both springs with solid blocker rods... If you gut the valve you lose dual isolated systems & the switch isn't designed to handle that kind of pressure..
It'll take a little measuring with something more accurate than a carpenters tape measure but I think you got this... LOL
With the dual isolated system if you have a leak you only lose the brakes on one end of the car...I already gutted one. I have not swapped it in though.
The switch could be replaced with a brass plug like the one on the bottom of the block. It didn't occur to me that fluid pressure could get past it.
The other way to go is to simply plumb the system without a common "manifold" block.....MC lines directly to the front left and right and the rear line.
I'm curious what difference there would be between plumbing both MC lines to a common open on the inside distribution block versus plumbing the front and rear apart from each other.
Vinegar is the most under rated acid / solvent in our hobby. I use it on everything. Mild but give it a little time and it works wonders. Go for it.The exploded view of the 68 and later A body 4 wheel drum distribution block:
From the bottom…
End cap
Tension spring
Collar
Shuttle valve. Warning switch to the right.
Collar
Tension spring
To get it apart, the end cap comes off. Some are 1/2”, some are other sizes.
The warning switch is 5/8”. It comes out. The lower spring should fall right out. The lower collar needs needle nose pliers. The rest had to be pushed from above.
I used a #8 trim screw.
Threaded into the input passage at the top.
It pushed the top collar down enough to get leverage on the shuttle valve through the warning switch hole.
Now I need to soak this block in something.
Any suggestions?
I’m going to try this:
the wider the tire, the less prone to skidding, more grip to the road will force the rotor not to lock but come to a quick stopFrom the "glaringly obvious" department:
1. Disc brakes were originally thought by engineers to be preferable to drums because the design
inherently resists locking up better than drums.
2. Modern tire compounds, especially those of some performance brands, are formulated for maximum
grip - i.e., resistance to losing contact with the road surface.
I'd imagine the same qualities that make them so darn good at not sliding going around a corner also
makes them darn good at not sliding under braking, eh?
On dry pavement, yes. Not so in the wet or snow. Not sure if this explains KD's lack of braking power.the wider the tire, the less prone to skidding, more grip to the road will force the rotor not to lock but come to a quick stop
