Broke my 7UP Pop Machine today....(Superbird Restoration)
Blast cabinets are a double edged sword... The parts turn out great but you can burn hours & hours leaned over a little dark window.. I have a fairly nice cabinet, dropped a grand for it back in the mid nineties.. These days I gather my pieces & head to my buddies auto machine shop... His commercial cabinet can do in ten minutes what mine takes an hour to do..
That was the biggest down side to retiring. Had access to a steel shot machine along with an industrial bead blaster plus larger engine lathes and mills when needed and working the off shift allowed the few of us working that to do things for ourselves. Even the surface grinders came in useful a few times....
On the railroad, we had more than one set of stamps in the tool room. Likely was the case here too.
Yep. Just gave me a giggle considering how bent out of shape the "experts" get about correct stamping fonts when about anything can go.
Worked in a steel mill in the mid 70's and bid into the roll shop and stenciled the rolls after they were finished being remachined. Hey, sometimes I'd speeel ARMCO wrong :D
Currently I would love to have access to a surface grinder.... And I'm working on it....
Not much done today after losing 1/2 the day to following my tree markers around the property, but some scrubbing bubbles to clean up the vent window seal.
Regulator bracket channel needs to come off.
Quick rap with a punch to remove the center mandrel.
Rivet, gasket, bracket and glass.
Managed to save the "H" slider pins on the slider mylar on this one. The mylar itself it toast after 53 years.
Pulling the OE door glass to quarter glass seal out of the stainless glass trim edge, seeing the trim edge fell off during handling. I was hoping I didn't have to reset it, but **** happens. I'd bought a "new" piece of trim off an FBBO member for this side, as mine is dinged at the top, but turns out what he shipped me is a drivers side.. ffs.
3439022 is the original part number 82750 the vendor.
New 32230 mylar ready to punch holes for the slider pins, cut to length and install.
How long do you leave the scrubbing bubbles on there?
A minute or two and then wipe. Stuff is the BEST cleaner I've ever used on vinyl roofs. It lifts the dirt out of the grain...
I have a steering wheel in my 97 diesel that needs cleaning....and absolutely nothing has worked on it yet. It was bad when I got it in around 2001 and got it better but still not happy with it.
I'd bought a used door glass rear edge trim for the "passenger" side, but turns out it's actually a drivers side. So I guess I'll fix the one off of the car that's been damaged since I bought the car. You'd swear it went through a pop machine...
Full of dings and dents so I punched those proud from behind.
File all the lumps smooth.
Work through the sand paper grades starting with some 220.
400/800/1000/2000
Then onto the buffing wheels with Black on the hard wheel and green compound on the soft.
Guess that'll do !
Need to run the glass rear guide channel through the blaster before installing the new rubber/felt.
Removing the glass setting tape from the glass rear edge trim. This one let go a lot easier than the drivers side did.
Quick clean with some 80 grit so I can reset the trim onto the glass with setting tape.
New flocked seal ready to go into the trim.
Seal pushed down into place and then the small lock tab forced into the trim with some plastic trim tools.
Extra seal cut off to the profile of the stainless trim.
Needs a bit of clipping to clean it up, but ready to install back onto the door glass.
How old are you these days?? Man, at my age, there's no way I could do all of this!
LOL Dave, 61. Hurt every forkin day, but I have since I was 18...
Didn't start hurting until about my mid 30's and even then, it wasn't too bad. Now if I pick up a half full bucket of water, I need to do it just right or it'll make me hurt for a couple of days at least.
I’ve done a fair amount of trim repair, straightening and polishing. I can vouch for it being very tedious, hunched over a bench or buffer for hours, peering at surface reflections, waves, tool dings, and fine scratches. It’s a tough job to do right. :thumbsup:
