Crank no start
1:39 PM
minnesota
67 Satellite with a 500 stroker
Two weeks ago I had spark had to change the torque converter because I wanted better stall (and I managed to knock a couple teeth off the ring gear)
Today it won’t crank when I key it, but I get 14v at the coil. It cranks when I jump the starter under the hood.
No ballast resistor, it has the ignition system from 4 seconds flat
Where should I look?
I chased the same problem and it turn out to be a bad battery connection,dirty.
Check the connection at the neutral safety switch if you have the single pole version.
Starter relay? I've gone through 2 so far in as many yrs. If you have voltage at coil, try jumping relay. If it starts n runs, I put money on relay.
Most likely the neutral safety switch wire/connection was broken when you removed the trans.
Check the transmission linkage. If it's not in park, neutral safety switch would be open and it won't crank.
Try to start it with gear selector in neutral
did we get it started?
I have the 4 seconds flat ignition, including a new distributor with custom curve for my car. Awesome setup.
I concur. I was told it was "definitely" the neutral safety switch. What I did was apply the e-brake, turn the key to START, hold it there and move the shifter from park to 1st and back again a few times. No crank, no start. Installed a new starter relay and haven't had a problem since.
