67Satelliteman
67 Satellite with a 500 stroker
Two weeks ago I had spark had to change the torque converter because I wanted better stall (and I managed to knock a couple teeth off the ring gear)
Today it won’t crank when I key it, but I get 14v at the coil. It cranks when I jump the starter under the hood.
No ballast resistor, it has the ignition system from 4 seconds flat
Where should I look?
Thanks
Thanks
