Crank no start
12:19 PM
minnesota
67 Satellite with a 500 stroker
Two weeks ago I had spark had to change the torque converter because I wanted better stall (and I managed to knock a couple teeth off the ring gear)
Today it won’t crank when I key it, but I get 14v at the coil. It cranks when I jump the starter under the hood.
No ballast resistor, it has the ignition system from 4 seconds flat
Where should I look?
Thanks
I chased the same problem and it turn out to be a bad battery connection,dirty.
Check the connection at the neutral safety switch if you have the single pole version.
Starter relay? I've gone through 2 so far in as many yrs. If you have voltage at coil, try jumping relay. If it starts n runs, I put money on relay.
Check the transmission linkage. If it's not in park, neutral safety switch would be open and it won't crank.
did we get it started?
Thanks
Thanks
I have the 4 seconds flat ignition, including a new distributor with custom curve for my car. Awesome setup.
I concur. I was told it was "definitely" the neutral safety switch. What I did was apply the e-brake, turn the key to START, hold it there and move the shifter from park to 1st and back again a few times. No crank, no start. Installed a new starter relay and haven't had a problem since.
