1970 383 Ground Cable Connection
Chargerjase
9:44 PM
Kiel Germany (back again)
I wonder if anybody has some detailed pictures of the connection from the negative battery post, to the block? Also carb linkages and throttle spring details. Carb is a 4 barrel Carter and I have an RV2 compressor mounted for air con. I realize this has probably been asked before, but my search turns up nothing definitive. Factory original please.
Thanks.
Note that factory correct there ISN'T a washer under the bolt head!
Ah that's brilliant thank you Wayne. Do you happen to have any picture of your throttle linkage by any chance?
Ah right, no worries. I am also running a Holley, but want to gather the parts before I swap over to the Carter.
