TL44
70 RR 383, 4-spd, Edelbrock carb, Carter mechanical fuel pump. The car will idle fine and drive good for about 20 minutes and then it starts to hesitate and just stalls out. I'll check the carb and it's not getting gas, if I pour a little gas into the carb it starts back up (this is how I got it home twice) I've been able to recreate this in the garage, started it normally let it ide and it stalled out at 22 minutes and then a few days later after 40 minutes, same thing , no gas pumping into the carb. I just put in a new Carter mechanical fuel pump & push rod (from Mancini) with no change at all. Anybody run into this kind of problem? Ideas? All appreciated.
