- 10:54 AM
- Dec 4, 2009
- Pasadena, Texas
Or wire in a 0.22 microfarad capacitor across the resistor to smooth out annoying noise.
Yeah, 318 springs aren't going to control the torque of a 440 very well. My 440 RT Challenger ragged top banged the flood just like Myasylum's car but it didn't have a factory snubber and wasn't about to us and adjustable one as I do NOT like them. Anyways, once the factory snubber was in, there wasn't anymore problems hitting the floor anymore and no wheel hop.I had wheel hop on my 1970 Charger when I first got it. It was originally a 318 car, but had a 440 in it. It was like a jackhammer. The first time it happened to me, it was so violent I was sure something broke. This was 20 years ago, I bought a set of the Mopar Performance 440/Hemi springs and it never happened again.
How much power does your car have now? I'm hearing that you've done a ton of modifications to the car and wondering if the springs were what came in the car and if the engine is producing way more power than the original engine did. If that's the case, then yeah, upgrade the springs too but a factory snubber will cure the driveshaft banging problem.....I wouldn't say I have wheel hop. This just started maybe a month ago and gradually gotten worse. I think the springs have just gotten weaker with age, plus with the added torque it's gotten worse.
I'll start with pinion snubber, but I'm sure I'll need springs.
And what is stock height? I don't even know?
Btw... I have no ballast resistor. I've got you all beat.
I suspect there was a rear spring clamp missing cause I've beaten on plenty of Mopars with the light duty springs and a lot more engine than was original... Never had wheel hop.... Stock Nova? Holy Sh!!... Stock Mustang? Oh Yeah... Those both have the axle nearly centered on the spring.. Mopar from segment is only 20" so it's much more resistant to wrapping up...I had wheel hop on my 1970 Charger when I first got it. It was originally a 318 car, but had a 440 in it. It was like a jackhammer. The first time it happened to me, it was so violent I was sure something broke. This was 20 years ago, I bought a set of the Mopar Performance 440/Hemi springs and it never happened again.
The "real" fix beside the ballast resistor is the "GREEN" axle bearings.....which are attributable to just about all rear end difficulties.......said with sarcasm and tongue in cheek.......What size ballast resistor do you have?
By looking at the picture it looks like the u-joint end caps don't have retaining clips to hold the u-joint in the middle of the pinion yoke.its automatic. I just have to drive nice for a while. Still makes me nervous though. Snubber on the way!
Looks like a D60 with U bolts... Those have tabs to retain the caps.. No clips required...By looking at the picture it looks like the u-joint end caps don't have retaining clips to hold the u-joint in the middle of the pinion yoke.
If it was me I would check the u-joint for movement after that floor banging.
Put a pinion snubber on it & go for a drive... All will be revealed...Yea, I'm a little nervous if other damaged occurred too. I'll take a look at that, Thank You!
Re balance the drive shaft. IDK?
I remember the first time I drove a new first gen Camaro small block with a stick. I took off easy and then nailed it and it broke loose and hopped like crazy! That was the first time I experienced wheel hop and thought the rear end was about to come out from underneath the thing....I suspect there was a rear spring clamp missing cause I've beaten on plenty of Mopars with the light duty springs and a lot more engine than was original... Never had wheel hop.... Stock Nova? Holy Sh!!... Stock Mustang? Oh Yeah... Those both have the axle nearly centered on the spring.. Mopar from segment is only 20" so it's much more resistant to wrapping up.
Low HP 1st gen Camaro ran a single leaf spring... Those cars has the worst wheel hop I've ever experienced... Anything running 290HP or more got multi-leafs & didn't act nearly as bad...I remember the first time I drove a new first gen Camaro small block with a stick. I took off easy and then nailed it and it broke loose and hopped like crazy! That was the first time I experienced wheel hop and thought the rear end was about to come out from underneath the thing....
What exactly would be revealed? What should I look for?Put a pinion snubber on it & go for a drive... All will be revealed...
A good clue would be vibration.... If it's smooth chances are good nothings wrong... If there is a vibration there are plenty of things that could cause it so don't automatically assume it's connected... You have eyes, do you see any damage? Dents in the shaft? If it just rubbed a little paint no biggie, if it gouged the steel shaft you might wanna look closer..What exactly would be revealed? What should I look for?
My point exactly.I had wheel hop on my 1970 Charger when I first got it. It was originally a 318 car, but had a 440 in it. It was like a jackhammer. The first time it happened to me, it was so violent I was sure something broke. This was 20 years ago, I bought a set of the Mopar Performance 440/Hemi springs and it never happened again.
A ballast resistor.What should I look for?
This is bordering on hilarious.....A ballast resistor.
