Hi all, I have been thinking about selling my 68 recently due to how little I actually use it and am curious on what the popular opinion is on how much it might be worth if I do. I haven't committed one way or the other. It has sentimental value but also takes up a lot of space and gets used very little. It is currently in Wisconsin.
Some of the details are:
Originally a 318 car. Currently has a 440 in it. It was a bare metal restore (if you can call it a restore?) in 1995 for which I have most of the receipts for.
Rust free, paint is fine from several feet away. It is single stage. Has some cracks in the paint, some flakes missing showing the primer etc. Looks fine as is but that would/will be my next move.
General details
440 bored 30 over
292 Purple Shaft cam
6 pack pistons
Double roller timing chain
Polished crank in '95
ARP rod bolts
Trickflow Power Port 240 Aluminum heads
Edelbrock Performer RPM high rise manifold
850 cfm Custom Pro Systems double pumper carb
MSD 8546 distributor
MSD Blaster 2 high performance coil
MSD 6-AL Ignition kit
Taylor 10mm Racing wires
Iridium spark plugs
727 torque flight with manual valve body shift kit
Trans Cooler
Lightning stick shifter
Blue plate clutches
B&M Holeshot 3000 stall torque converter
3.91 8-¾ rear
Hooker Super comp 2” primaries 3.5 collector.
3” Flowmaster exhaust
Optimum red top battery
KYG gas adjust shocks up front
Refurbed stock suspension
1.14” torsion bars
215/70/14 front 325/50/15 rear
Manual front disc brake conversion w/ line lock
Power steering leaks.
Most guages are a guess if anything.
General details
440 bored 30 over
6 pack pistons
ARP rod bolts
Iridium spark plugs
Trans Cooler
Blue plate clutches
3.91 8-¾ rear
1.14” torsion bars
