62-65 727 tailshaft bearing part #?
icetech
9:13 AM
Macomb Mi
Getting ready to put my trans together but missing a few parts still.. on the early 727s the output shaft bearing is all the way at the back of the tailhousing.. would anyone have a part number for that? or is it the same as the mid bearing on the 66+ trans?
Could use a new TV rod seal but they seem to not exist.. will keep looking for that
Do you have a flange or a slip yoke style drive shaft? The TV seal should be in your seal kit but, some times you need an extra seal set for the early 727s.
Flange.. i went through the kit last night and i think they are in there.. what surprised me was no thrust washers/fiber washers.. glad i kept my old stuff
P.S. trying to find a slip yoke tailshaft/housing.. nearest one i have found so far is 9 hours away.. one will show up eventually though :)
You need to also change the input shaft and front pump drive so that you can use the later style converter.
Yup, already done.. picked up a beat up old 727 last week and am transferring the 2 front drums and input shaft from it.. i'm ordering a converter today... :)
1965 tail shaft and housing is the only one that will work on your cable shift transmission. Any 1965 C-body will have one. Even the ones on small block (Poly) 727 will interchange.
yup.. just a matter of finding one :)
