- 8:36 PM
- Dec 31, 2020
- Ontario, Canada
After working on my 1964 Dodge Polara, since the Pandemic, I figured I had it ready to fire up today. My buddy and I worked on it Saturday and today and got the 440 engine running, only to find we had no oil pressure. I had tried priming it with my power drill, and foiund it only had a slight resistance when spinning CCW, and none when spinning CW. I know the pump and distributor run CCW. I have primed other big blocks, and when they start to achieve pressure, it almost jerks the drill out of your hands. This was not the case today. Yesterday, I had the restricter valve and spring out of the pump, thinking maybe the valve got stuck in the bore. I cleaned everything up and replaced the stock blue spring with a stiffer black one. I have a new filter and 5 L. of 10 W 40 oil in it I have the stock sender with red light in the dash, plus an aftermarket mechanical gauge under the dash. Neither gauge showed any pressure. Curiously, the hydraulic lifters were not clattering.
The car has not been on the road for 20 years, but I would occasionally fire the engine up to make sure it did not get stuck. The car was a strong runner when I parked it in my new heated garage 20 years ago. When I had the engine out of the car about 4 years ago when the car body was getting restored, I pulled the intake,water pump, and heads off and put new gaskets in it. At the same time, I coated everything with GM.Engine Oil Supplement. I use this stuff at every oil change in my old cars. I don't think the engine has 10,000 miles on it since a quality rebuild. I figure that either the pump or filter has f**ked up. After talking to a couple of Hemi racing buddies, I think that the inner rotor and shaft have separated. I have a new Melling M63HP pump on order from RockAuto (made in USA). I had it all lined up for new exhaust for tomorrow, but cancelled that. I am pretty disappointed. After working on these early B-bodies for about 50 years, this is not my first rodeo.
