62maxx
Good Evening,
I'm having a MIGRAINE trying to fit a TTI Exhaust system on my 62 Polara 500 2 door. I gave them both HP manifold numbers for the supposedly "correct" down pipes and per the destructions, to begin assembly from the rear. We mocked them up anyway just to see and BOY what DO we see? The drivers down pipe seems not to be bent correctly as it takes the drivers side half of the "H" pipe WAY over towards the drive shaft. Also, both halves of the "H" pipes are way too long to even fit into both mufflers and I DO have the correct Dynomax mufflers as recommended. I called them and the TECH guy (very cool dude) said to put the drivers side "H" pipe onto the drivers side down pipe and BEND the down pipe outwards towards the drivers door. We were thinking if we DO that, then the "H" pipe halves will NOT fit up and connect together. I've searched for comments and videos and found only TWO videos that were "out there" and not related to my issue. I have not bent anything as of yet. TTI confirmed my HP exhaust numbers and I "supposedly" have the correct stamped down pipe part numbers. I'm thinking the down pipe was not bent correctly? Any comments or remedies to this issue will be greatly appreciated!
