Jonas Nordstrom
Not sure, the K member to frame bolts looked untouched and still had some grime on them. Original sway bar also looked untouched and everything fits perfectly around the K member.Is the K member correct for the year car? Is there a chance that you have an earlier K member in there? I thought that I read that The 1962-65 units fit but the motor mount brackets move the engine further forward on the earlier K members. Do you recall the thickness of the mounting bolts? 7/16" is what I recall was my size in the '70 Charger
This is strange. I've only read of the Borgeson bolt hole issue to exist is when installed in the earlier model cars.
...though my car came with a 413 from -63, so anything is possible.
My bolts are 7/16.
