More.
That thing is beautiful. The 65 grills are easily in my top 5 fav on any mopars. You got yourself a real gem there. Coronets just have a look to them that I cannot resist.I've finally had time/funds to get after updating my 65 Coronet. This car is the one that was used for the cover of the old S A Design suspension and handling book from years back. My friend, Jeff Williams, that used to own it was friends with Larry Schreib and Larry Atherton of the publishing company. I bought it back in 08 after losing my 70 Challenger in the 07 fires that went through here. I did some basic upgrades on it when I first got it. New TTI 2" headers, 3" exhaust system, tires and other minor stuff. I started buying and stockpiling parts and assemblies for it knowing which direction I wanted to take it. I made Firm Feel happy, Indy Cylinder head for the new alloy bullet, Pro Trans for the 727, Gear Vendors OD, Dr Diff on the Strange Dana 60 plus 4 wheel disc brakes, ART [auto rust technicians] for structural pieces, Ron Francis for wiring, AEM on the efi brains, TTI for headers, Be Cool for the new radiator/fans unit, SD Concepts on the serpentine drive, Bergman Auto Craft for the Borgeson unit, Master Shift for paddle shifting, US Car Tool for spring relocation and mini tubs plus more to come. I already have the engine/trans out to start fitting things up. Figured this would be wise since I'm using a 70 k-frame. Pretty much cut and dried up front but in the trans extension housing area, because of the GV extension/adaptor, I will have to do some remodeling on the floor because its got almost as much girth as a 518 trans in that area. If I had gone straight 727 it would be close but no issues of hitting. I have found some old car damage as far as stress cracks in the rh frame rail where the k attatches and the passenger compartment floor. These along with excess hole will get welded up. The only holes on the firewall will be for the master cylinder, steering column and my planned old school NASCAR cowl induction. I have also spent some time working the k over with a bunch of reinforcing and added plug welds[ 100+ over the factory 30 or so]. Once I get things fitted up, I'll strip the engine compartment of paint/junk etc, do all the metal work then paint the area again after which I'll move to the middle for structural pieces then the back for its portion.
View attachment 353928 View attachment 353929 View attachment 353931 View attachment 353932 View attachment 353933 View attachment 353934 View attachment 353935 View attachment 353936
Neat!Today I marked out the cuts on the bumper and commenced making sparks/grit. From there, de-burred all of the pieces then started putting pieces together. I have the basic unit together now. Tomorrow I'll start fine tuning it. For those going WTF? the reason I did this is because my three oil coolers are behind that opening. With it being now widened, they will enjoy the extra airflow.
