sam dupont
You can buy used race rubber on line. Still sticky, but much cheaper. If you have the cash, buy new race rubber, it's really stickyany recommendation for 200 TW tires to fit a 15-inch wheel? What are you using?
I'm not actually yet. I have some 15" rims and I'll probably swap them on and off as needed. Im using tire rack and just searching 15" tires that i can make work. Budget hasn't allowed me to buy yet. I'm currently running on 14" magnum 500 style rims with Cooper cobras. I think the main thing people need to realize is that you're going out to have fun. You aren't going to set the fast time at all. Even in the vintage classes where you match up against other vintage cars you will still get beat, especially in a B body, unless they're a poor driver. But you'll have a blast and my goal is always to get the best out of my car that day. When I clock 2 or 3 runs within a tenth of each other and don't feel I could have changed a single corner to have been better I feel successful.any recommendation for 200 TW tires to fit a 15-inch wheel? What are you using?
Here's a in car video using the trackaddict app. Sorry for the talking in the video.
I would think a 200 tread wear wouldn't last very long on the street. Probably too expensive for me.You can buy used race rubber on line. Still sticky, but much cheaper. If you have the cash, buy new race rubber, it's really sticky
I agree, the only reason I want to Auto cross it is just for the fun. The only numbers that would concern me would be comparing them to the last time.I'm not actually yet. I have some 15" rims and I'll probably swap them on and off as needed. Im using tire rack and just searching 15" tires that i can make work. Budget hasn't allowed me to buy yet. I'm currently running on 14" magnum 500 style rims with Cooper cobras. I think the main thing people need to realize is that you're going out to have fun. You aren't going to set the fast time at all. Even in the vintage classes where you match up against other vintage cars you will still get beat, especially in a B body, unless they're a poor driver. But you'll have a blast and my goal is always to get the best out of my car that day. When I clock 2 or 3 runs within a tenth of each other and don't feel I could have changed a single corner to have been better I feel successful.
I think people get too hung up on having the best stuff and being the fastest. You should be going to have a good time. You're not gonna embarrass yourself unless you putz around like an old lady or you think you're max verstappen and take out a bunch of cones. The last autocross I went to, the fast time of the day was 54.5 sec set by a Porsche Cayman. My best time was 67.1. That's a huge difference sure but there's a huge difference between that new Porsche and my 50 year old worn out junk.
Yeah but HoooOOOOOlee crap do they stick to the road!I would think a 200 tread wear wouldn't last very long on the street. Probably too expensive for me.
You could start with the easy stuff and advance from there. Grippy tires, sway bars and some Bilsteins. If the front joints, bushings etc are questionable you'll want to address those first.I agree, the only reason I want to Auto cross it is just for the fun. The only numbers that would concern me would be comparing them to the last time.
I have 200 TW tires on this car:
My first set of tires for this car "aged out" at 70 % tread up front and 50% tread out back. I had them right at ten years.
I replaced them in 2014 and am ready to replace them again this year but now they are worn out. The car has never handled better than it does now.
I feel like this guy.....
This site seems to have the most events listed and it’s nationwidelooking for some of these road course type events in the midwest, especially michigan, who puts these on?
Upgrade springs, add sway bars front and rear, and maybe upgrade tires. Get a full alignment and you’ll be set. Anything beyond that gets expensive and possibly makes it less streetable. Follow my recipe at the beginning of the post.I have a 63 Dodge b-body I'm looking for ways to make it handle better. It's not a race car just Street. Was wondering if it would be practical to use offset shackles on the rear eyes of the leaf springs. Any other advice for handling I would really appreciate. Thanks in advance, Dave
Better tires are the next step for me. I just don’t want to give up that old school stock car look and running race tires on the street are questionableYour tires are protesting at 7:45 and the skid marks on the road say many before you found the limit of their traction.
Curious on why you think I should disconnect the rear sway bar?For the OP, I not true believer in anyone starting out with a rear swaybar. I haven't seen anywhere in this thread where you tested your set-up with the rear SB links disconnected for an A/B comparison test, I would highly suggest it and suspect you would find it informative. Three things stand out for all the readers here IMO, big TB's. 1.1" is the min that should be considered, 1.03" is a waste of time and money on the track but still an improvement over stock, and one the owner/driver will quickly regret, -1.0deg camber is also a min, and lastly tires are everything and above all else in handling.
I started off with one for a couple reasons. First, the factory handling packages in T/A, AAR, and Police cars had them. Second is most aftermarket kits have them as well. I would expect those kits to have a little R&D behind them and most seem to work well with what research I did.
Honestly I’m pretty happy with my setup as is.
That is your contribution on the topic?If you are the same JCC from Moparts, I’d take his words with a grain of salt. That dude loves to criticize every mod people do. He railed against 11/16” tie rods in the A-B-E cars, the lower control arm reinforcements, even had issues with frame connectors and torque boxes together.
Either scroll past his words or put him on IGNORE.
