Square back alternator field wire size ?
rustytoolss
1:56 AM
New Franklin, Ohio
My square back alternator field wires need replaced. I found Standard Motor parts S79 connector kit $7.99...but it says the wires are 18 gauge. Is that lare enough, will it be a problem. My alternator is a 65amp unit.
IIRC 18ga should suffice for the field wires. Your FSM wiring diagram will confirm.
Always size for the worst, but you're talking field wires, so that's only like 4 or 5 amps IDB, even with a bigger alternator.
Given the opportunity, I would check them and see whats there amp-wise, before you rewire (prolly too late I know).
