PrescottJeff
Old carbureted cars constantly change. You could have any number of things going on. I didn’t see what we are working on so for now I’ll assume you have electronic ignition and we will say that’s good. I suggest you find the 2 air/fuel adjusting screws under the front edge of the carb. DON’T just start turning them, instead turn them both 1/8 turn counter clockwise (rich) If it runs better you’re good. If runs worse go clockwise 1/8 to get back to your starting point plus an additional 1/8 in (lean). Again if better you’re good. If not 1/8 CC puts you back to your starting point and you have eliminated a minor A/F adjustment. I can’t tell you how many cars I’ve fixed where some weekend warrior just started turning screws until it’s all F’ed up. If you’re careful about knowing how to get back to where you started and not making huge changes you can learn a little about your car.
On the bright side, there's only three vacuum spots to check. If no luck, I'll pull the carb and try a new gaskets between the intake, heat shield, and carb. If still no luck... then I don't know. ....
