69hemibeep
My daughter insists on 18's. Maybe a 7" front wheel 10" rear and what size tire works without clearance issues?
			May be a but of a challenge putting 18's on, it can be done, but clearence issues are possible.My daughter insists on 18's. Maybe a 7" front wheel 10" rear and what size tire works without clearance issues?
I always forget, did you altern the rear inner fenders on that one or the other one?This car:
Uses an 18 x 9 up front with 4 3/4” backspacing and a 275-40-18 Nitto NT 05 tire. Rear has an 18 x 10 with a 295-35-18 Nitto NT 05 tire. The fronts only rub their sidewalls to the frame rails at full turn, otherwise no contact. Even then, the tires rub against a flat surface causing no damage.
The rears don’t contact anything.
That’s some wide wheel! What’s the back spacing on the back? I like itThis car:
I always forget, did you alter the rear inner fenders on that one or the other one?
Here is what I did.18x9.5 rim rear, 295/45/18 with 5.5" backspace.
17x8 front, 255/45/17 with 4.5 backspace
the hump in the outer wheel house of a gen2 charger is an issue. Options:
-run the 35 series tire on rear
Or
-don’t lower the car so much
Or
-relieve that hump.
You have to deal with it at some point because big wheels look dumb unless you push them out as close to wheel lip as you can. We cut and patched that hump on pass side but still have to do drivers side. It’s not a problem unless there are people in back seat or you load up with a bunch of junk in your trunk. all what I just said is for my car… which is pretty low.
