Berno's Garage
New Member
Hi guys!
i have a gen 2 hemi that i would like to get up to 700 street friendly hp if possible.
Spec on the engine now
Mp megablock 4.31" bore
Mp cast iron heads unported 2780559-M stage v rockers
very mild bullet hydralic flat tappet cam, dont have the specs.
diamond pistons
440 source 4.25 stroke crankshaft
440 source premium H-beam rods with arp 2000 bolts.
10.5 compression
Mp dual plane intake manifold
melling Hv oil pump
Moroso deep pan
msd ignition
Hedman headers
I will also convert to efi as I will drive an 8hp transmission.
Do you think it's possible to reach 700 street-friendly hp with only changing the camshaft and intake? or will the heads need to be ported or replaced?
the engine will run on e85 if its needed.
grateful for answers
diamond pistons
10.5 compression
melling Hv oil pump
Moroso deep pan
msd ignition
Hedman headers
