Thanks, guys, for your continued patience. It's nice dealing with people my own age, for once.
			I'm guessing your younger but honestly have no idea.... I was born in the 50's... Soooooo.....Thanks, guys, for your continued patience. It's nice dealing with people my own age, for once.
You didn't need to touch the intermediate shaft... That
s why I didn't mention it.... Now that it's been changed set the engine back on #1 TDC on the compression stroke... And aim the intermediate shaft like this...
Then install the distributor with the rotor pointing to about 5 O-Clock
Charge the battery, Static time the thing by getting #1 on TDC. Pull the cap and line #1 on the cap with where the rotor is pointing and install the plug wires in the correct order and direction of rotation/ correct rotation. THere should be no reason for it not to start unless you have bad parts or a Holley carb with a blown power valve.Update number two:
Cranked the car over for a while with no result. Turns out my " helper" forgot to plug in the distributor. Plugged it in and promptly got a backfire out the exhaust lol that you guys might enjoy that a bit.
Continue cranking. No result. Wondering if I ruined the plugs has number one was pretty dark when I took it out
Running out of battery life. My battery tender is away add another location at this time. I'm probably going to retire the car until further notice.
Those Unilite dists got the nickname Unidark....for obvious reasons. Only realised you were using one when I saw post #45. This could well be the cause of det if something has failed in the module.
I would replace the dist with a Chrys elect dist & use a 4 pin HEI module with it. Pics & wiring on the web & have also seen on this website.
Welcome to Mopars..... Glad it's made some progress.... But at least for a while get use to one step forward, two steps back...Another update:
I took everything out and started over. I moved the intermediate shaft to the suggested position. I installed the distributor per the instructions (I can't believe I had such a hard time finding them), then re-wired everything. No start.
Pulled the dist and rotated 180*. Car fired right up and runs better than ever with the new cap, plug, and wires. NOT TOUCHING ANYTHING ELSE LOL.
I have a perfect 750rpm idle and timing is holding perfect. Wanted to take it for a test drive, but it was dark and now, all of a sudden, the headlights and right half of the gauge cluster lights no longer work.
I swear if it's not one thing, it's another. LOL.
It can be aggravating, but when you get it all sorted to the point it stays sorted it can be satisfying & how ever it goes your gonna learn stuff.... So it's educational...I've had the car since Oct of '22 and that's how it's been the ENTIRE time. "Yes! I got it fixed. Wait, what? When did this stop working??".
The car is going to sit for a while. As it turns out, electrical is my worst subject (even more so than my carb and ignition issues) so I'll bring in some help to deal with it, unless I find a bit of extra time to tackle it, myself.
At this website you may download a service manual for your car. Don't know if you said what car you have, been dipping in and out to see how it was going. For engine trans and rear differential you only need a service a year or two of your car. Maybe 5 years +/- even. Service Manuals – MyMopar
Leave it alone. The old stuff is fine when assembled correctly as you have just seen.I'm actually about to pull everything and go with EFI/crank trigger/etc. All this old crap is starting to be more of a problem than it's worth. But for now, I'm glad that I can drive the car in the mean time... during daylight hours.
