nutz4spd
Would it do any damage to the bushing if I left it in the freezer over night?
www.forabodiesonly.com
Any suggestions on how? The machine shop here is closed on the weekends.Well your bushing is the correct size at least. As I expected your crank was never finished bored for a standard trans bushing. Turn the bushing down to 0.925
The ID in the crank measures .923 and the room temp bushing OD is .940. Even the frozen bushing OD is still .940 so that didn't make a difference. Glad I picked three of these up. It's going to be along Saturday...
I'd put it in my lathe and do one 1/2, turn it around and do the other. Find a long bolt to fit the ID that just allows the bushing to spin. Hold each end of the bolt, with gloves, and let the bushing spin and sand down on a belt sander.Any suggestions on how? The machine shop here is closed on the weekends.
One suggestion with those bearings: Drill and tap the bearing. Then if you have to take it out, two screws will easily pull it out for you!I just use one of these instead. It installs in the end of the crank and we’re used in Dakota’s.
