- 7:55 PM
- Jul 1, 2015
FYI.....humidity effects air density. The more dense the air, the more heat the air contains or the air is heavier. The shroud helps move the more dense (or heavier) air thru the radiator or heat exchanger for better heat transfer .......Just an fyi humidity affects humans but your engine temperature is purely temperature difference.
A shroud is a good idea.
BOB RENTON
