Okay guys (and @Kern Dog vintage air expert) here is where I'm at on this project.
Friend's brother who retired after 31 years as a Ford master mechanic came over to vacuum and charge. We watched the gauge at 28 inches of vacuum for a little over a half hour and he called it good. Using a scale he charged 1.81 pounds precisely. He sort of measured the high and low lines temperature and said all good. I didn't have the ducts hooked up, but he felt the evaporator expansion and said it was really good and cold. I paid him for his time and reassembled the car and connected the ducts.
The glove box liner instructions is a joke and without some Dremel fitting it could never have worked. Doesn't anyone at vintage air try to install this stuff?
So test drive time. Really mild weather here in Tucson and it's actually in the mid 70s, but I rolled up all windows and placed the AC on mid fan speed dash vents.
It's not really cold.
Back home I take a temp gun and measure the dash vents.
Temp lever at far left: 54 degrees
Temp lever at far right: 94 degrees
I call the guy who charged it this morning. He says grab the copper tube on the heater box and see if it's cold. It's so cold I can't keep touching it. He says "well that's a blend door issue call vintage air".
I sent a email to vintage air with a video of the compressor cycling. Not sure if there's anything else I can do to troubleshoot?
Thanks for any help.
Video link below
https://1drv.ms/v/s!AksXImgz5jdygqku0VUFnHaSaNI9tg
Video link below
