72 Satellite
Remind me again what size wheels are you running front and back? It looks slightly disproportionately higher in the front? BTW, absolutely love your ride!
Rob
Rob
Thanks for the compliment. I agree it looks a bit off. It's actually fairly level and the pinch seam is 3/8" higher in the rear, but it certainly doesn't look that way. I've got 18's in the front and 20's in the rear. I'll probably go higher in the rear eventually. I just needed to get the front where it needed to be so I could get it aligned.Remind me again what size wheels are you running front and back? It looks slightly disproportionately higher in the front? BTW, absolutely love your ride!
Rob
I have the RMS setup front and rear.Interesting, I've also got 20's in the rear and 18's up front. Do you have RMS front and rear, or just front? I have a rebuilt K-frame/T-bar up front, but a 4-link in the rear. I've got Doug's headers with no ground clearance issues. Only clearance issue I have is the darn 7qt Moroso Oil pan the P.O. installed. I was going for more of the 70's Raked look, as opposed to a more modern look. Must say I do like the lower, sleeker, modern look your ride is going for.
I've seen those used on few YouTube channels l. I'm trying to avoid something like that, but it might be my only option. Oval pipe is also an idea.You may need to get some pie cuts of tubing to help swivel around all of the appendages. There are some companies doing them out of Aluminized material but you'll need to do some hunting. This will give you an idea at least.
Vibrant Performance 13625 Vibrant Performance Pie Cuts | Summit Racing
Way better than trying to pie cut the pipe doing the cuts.
Are you talking about the grommet? They are readily available.Got my Essex mass backing carpet today and was disappointed to find the high beam bezel/cutout wasn't included. Any tips for how to add one?
Oh nice. I thought it was metal for some reason. ThanksAre you talking about the grommet? They are readily available.
Mopar A B C E Body 62-93 Dimmer Switch Carpet Grommet Rubber
