Good bye highway gears. Hello 3.55
Just swapped the highway gears I had (2.73 i think it said) in my 73 RR to 3.55. I highly recommend. After reading several posts in this forum of guys who had made the swap I gotta say it made a pretty big difference. My little 318 went from a decent little cruiser to a cruiser with a little bit of an attitude. Sure I'm not burning up the roads, but it sure does feel more aggresive. Thanks for all the great info on this site.
Yup. I put 3.55s behind the 360 in my '73 SSP (245/60-15s on the back). Gives it a bit more attitude while still only being a cruiser...or it gives me a bit more attitude :lol:
Last fall, my friend and I were out riding around in his 72 440 Road Runner GTX. It has an automatic transmission and 3.55 sure grip rear axle. We both commented about how the 3.55 was the perfect all around gear for a Mopar.
If I even could notice the 3.23 open to 3.55 SG swap (just a bit, but still noticeable) I can guess the huge WOAH you could exclaim with your swap after the first miles LOL
From seat of the pants feel I noticed the difference most in first gear on my basically stock, rather heavy 67 GTX with AC, power 215/75-15 radials and TF. With the 3.23 it could easily break the tires loose off the line in first just by hitting the throttle. But as the tires gradually started getting a grip I could feel and hear it start to pull the rpm’s back down I guess a little below the torque peak and then the tires would hook up and rpm’s start struggling back up climbing again.
With the 3.55s, just nailing the throttle (no need for loading the converter up on a 440), the tires start spinning and keep spinning long enough that once they hook the engine is apparently up on the torque curve and there’s no sensation of revs sagging and the engine lugging down. It’s just off to the races. I’m sure 2nd and 3rd are stronger too but it’s losing the rpm’s sag during first that was the most noticeable.
I decided that it would be better for me to buy a brand new Strange Dana 60,instead of paying 3 to 5 grand for an original third generation B body Dana 60,and have to rebuild it before installing it in the car. The Strange Engineering Dana was 3k delivered.
Yeah I did the same thing. I had an original B body Dana 60 under my '65 Coronet for 30 years. A guy I knew back in the '80's wrapped his 1969 GTX around a telephone pole. I bought the Dana 60 and the front disc brakes from him when he parted the car out. Think I paid $200 for both. 30 years later I sold the Dana 60 for $2000 and bought an S60 with disc brakes that was exactly the correct width for my car.
I changed out Fred's gears to 3.55's when I got him to the point where I could drive him and that's
fine - as others have said, 65 is about 3000RPM going down the highway in 4th, but he isn't a distance
runner (least not, with all that LOUD 3" exhaust under there cooking the occupants...).
Pretty normal stuff in Mopar world, in other words. Makes perfect sense to me.
If I were to start travelling distances with him though, two things would need to change:
That infernal exhaust and those gears, both to more friendly highway equipment.
In car camera at 120 mph in my Coronet. With 28 inch tires and 3.23 rear gears the engine is around 4700 rpm. Redline is 6000 which would be 155 mph
, I have a 4.10 Dana 60 in my 70 Charger R/T SE, it's a 4 speed car too. I will be going with some kind of overdrive transmission. I am leaning towards the A855 5 speed transmission. The car will have a 472 dual quad Fitech fuel injected Hemi in it.
Is already available?
It has been told has been out of stock for looooong time after several mechanic issues and customer claims and returns.
I've got 180,000 miles on the 55 Chevy I drove in high-school, ..... with factory 3.55 gears (3speed sticks got 3.70s, 3 speeds with overdrive got 4.11s. Iron,powerglides got 3.55s) 65-70 mph on the freeway was a daily occurrence for a couple decades.
My Coronet has a 2.94 gear but, with the 3.09 first gear in the aluminum 833 perhaps 225/70-15 tires, the off throttle acceleration will be OK. And I think the 70 mph revs will be pretty low.
I'm hoping to get 20 mpg on the hwy with the 318.
Time will tell.
You will like the 3.55 gears,they are the perfect cruiser gears. I just ordered a new Strange Engineering Dana 60 with 3.54 gears for my 71 Charger R/T. Someone robbed the driveline out of the car decades ago. The Dana 60 is s being delivered on Tuesday.
I was so happy to find out my plymouth I got from Dave had a 3.55 SG!!!
