Rod bearing clearance is not what determines the oil. Use the oil that makes you happy with your oil pressure.Because of this .0027 restriction, am I correct in assuming I should continue using 10w-30 because it will move through the restriction better than a heavier oil?
Sounds like stock rods. Normal. What main journal to you have; B or RB?So is this .020" rod side clearance a bad thing? Is it common practice by some builders?
Yep. It's a mess.Most all of the aftermarket rods today are going to give you more than stock tolerance for side clearance. I don't like it but that's the way it is.
Try some straight 30wt rotella. Inexpensive, easy to find, heavier base stock and still has zddp in it. Multi weights won't get you where you want to be.Ordered some Driven 10w-40 to give that a try. Curious to see if I can get 5 more psi at hot idle and hot cruise. If so, I will call it a day for now. If not, I'll put an uncut black spring back in.
I went from 10w-30 to 10w-40 to raise my hot idle pressure. Didn’t make any difference.Ordered some Driven 10w-40 to give that a try. Curious to see if I can get 5 more psi at hot idle and hot cruise. If so, I will call it a day for now. If not, I'll put an uncut black spring back in.
It's fine...So is this .020" rod side clearance a bad thing? Is it common practice by some builders?
Thicker oil will generate more oil pressure on the gauge, but that isn't necessarily a good thing. More oil pressure due to thicker oil is not the same as more oil pressure due to more volume. What you want is more volume, not thicker oil. Thicker oil doesn't provide better lubrication, more volume would. They are totally different things but it gets confusing since the oil pressure is higher either way.Ordered some Driven 10w-40 to give that a try. Curious to see if I can get 5 more psi at hot idle and hot cruise. If so, I will call it a day for now. If not, I'll put an uncut black spring back in.
Whole lot of difference between 30wt and 50wt. I'm not 100% with you on this because I've been thru this. I don't like heavy oils and use straight 30wt as my limit but an hv pump will only make very marginal low rpm differences and I think he already has an hv pump on the engine. There are no band aids for this.Thicker oil will generate more oil pressure on the gauge, but that isn't necessarily a good thing. More oil pressure due to thicker oil is not the same as more oil pressure due to more volume. What you want is more volume, not thicker oil. Thicker oil doesn't provide better lubrication, more volume would. They are totally different things but it gets confusing since the oil pressure is higher either way.
When you have a loose engine you need a higher volume pump to maintain the oil pressure. If you already have a HV pump then the next step is a higher HV pump such as the Milodon pump.
Using thick oil rather than a high volume pump is dangerous. You can destroy the engine if you go down that road too far. I once blew up a nice 426 on the dyno by making that mistake. Put some 50 weight in it and we spun some rod bearings at WOT. The oil pressure gauge showed 70 psi when the engine blew. There was 70 psi at the pressure port on the back of the block but the rods were not getting enough oil volume because the oil was too thick to move thru the passages in the block.
Woah now, none of that crazy talk about selling stuff. You've already done the homework with the engineAll this new info is really starting to perturb me more and more. A guy like me who really knows nothing about engine rebuilding searches out a shop with a great reputation to build a motor. No talk on my end of going cheap anywhere, just do it right. Several thousands of dollars later and stuff like this comes to light. Both my big blocks have now been rebuilt 4 times within the last several years. So you guys can imagine the amount of cash I have tied up into them. I would be willing to bet the vast majority of people in the old car hobby have the exact same issues as me and are not aware of it. I'm about ready to sell all of them and just play around with my old Ford tractors instead. At least with those, costs are way less and I can do 95% of everything myself in my garage. Also no need to worry about dinging up a 15K paint job.
