Air Cleaner Help
I like your flat top plate with the recess for the wingnut, this alone would give you an extra half-inch to an inch or more. Was that something you fabricated or part of a complete assembly from Ramairbox? I would dig one of those in 14". I'm using a K & N 14 x 3" air cleaner, a 1" plastic spacer beneath it, and a 3/4" carb spacer. It all barely fits under the hood of my '70 Charger.
Top and bottom were from ramairbox. You will have to check with them on available sizes.
Ohh interesting, not what I was picturing in my head. I am realizing now that I think my search results pulled up six pack style intakes as well. Maybe that is where I am getting confused.
I made a rubber mold of the original football type. You can borrow it and make a couple in fiberglas. Bases are simple and could be made with thin steel sheet. This is the shorter version for 2x4. For a single 4, they were taller.
Original paint football above, my 6-Pack version in Dupli-Color DE1604 (Olds engine color) below. So close, any difference may be the new paint compared to old, engine cooked color.
Even with stock exhaust manifolds, those air filters probably can't flow enough air!
finding useful numbers on filters is lengthy and mostly unfruitful journey. There is no good research (that I could find) to exactly determine how much air a carb/engine requires. Analyzing what aftermarket suppliers have done, many are at the minimum required or less to fit under hoods.
With the air cleaners I made, I determined a 6 pack carb sucks approximately the same as a Weber DCOE 44. So I bought K&N's of that size. It's all still theory as I haven't found anyone with a running 6 pack to run them and find out.
I'm a shade tree everything, but here is something I found in my research for someone smarter than I to explain :
So assuming an atmospheric pressure of Patm = 14.7 psi, and an engine volumetric efficiency (referenced to manifold conditions) of VEe = 1.0 (i.e., 100%), one gets
(2a) CFM = 0.5*(Pboost/14.7 + 1)*CID*RPM/1728
Or
(2b) CFM = (Pboost/14.7 + 1)*CID*RPM/3456
Since K&N says their filter material flows 6.03 CFM per square inch, or 6.03 CFM/in², (probably at 28 inches of H2O), then all that's required is to divide (2b) by 6.03 CFM/in² to get the filter area required by as determined at maximum rpm, RPMmax, i.e.,
Square inches of filter = (Pboost/14.7 + 1)*CID*RPMmax/(3456*6.03)
Square inches of filter = (Pboost/14.7 + 1)*CID*RPMmax/20,839
I have noticed or at least convinced myself that the Edelbrock dual 4 air filter does not flow enough for my application. I made a baseplate that allows the use of a round 14" x 3". I came to this for the reason that the Edelbrock air valve secondaries did not flow enough air to pull fuel. I adjusted the air valve to open soon er and later . I tried without any air filter and secondaries worked well.
Or
Almost a year late, but.... engine masters did a aircleaner and filter shootout, with 19 different combos, on a 750 hp bbc.
A single 2 1/2 x 6 1/2 cost 140 hp. EM said it might support 250 hp with no loss of hp. (so, how much for a pair?)
Also part of the test was a Mopar dual snorkel. With one taped off, cost 94 hp, both open cost 53, and with the lid flipped, only 11.
The top seven or so filters cost almost nothing, and two actually made power, over no filter at all.
The episode is available on you tube.
