- 10:32 AM
- Apr 13, 2012
- Granite Bay CA
For the record, the Griffin "exact fit" I got is nearly 3" thick. As such, it negated the possibility of using a clutch
fan - not enough room for one, not even that popular "stubby" one from Hayden.
A direct drive setup was employed instead, using a 19" 7-blade fan with factory shroud.
For several months I had Dwayne’s Plymouth here in my garage as I did a few things to the car. He has an aftermarket aluminum radiator in it that uses two 1 1/4” tubes. Add that to the fins and case and that was a thick radiator. The 2947 Hayden was the only unit that I knows of that would fit. We tried a fixed blade fan at first that pulled a LOT of air but sounded like a jet turbine it was so loud. Either would have worked, the fixed fan or the clutch mounted one. The car got a aftermarket HVAC system so cooling was going to be of real importance.
So RJ, doesn't Hayden manufacture that fan clutch ? I thought so.
