katmachine62
Yeah I've already done all of above hey... Except post on general forum!Mate I'm out of ideas unless you haven't really got 10:1 compression and it's much higher, or the TDC mark on your balancer isn't correct.
If it's still detonating at only 6 degrees initial with the vac advance plugged then I don't know, but there are many others on here far more knowledgeable than I am - maybe put it on the General Forum and see if you get more input?
Also can you go back to the engine builder and see what he says? Verify what he's given you?
Engine builder bump steers me to tuning specialist in Daylseford, but I'm going to try a local dyno tuner in Mornington in about 5 weeks...
That way he can verify the timing mark I've had fabricated and set up (I've verified it as fast as I can), but doesn't hurt to double check of course...
I can't even run 5 deg without detonation which is really frustrating as it runs so much cooler and starts so much easier at 8/10 deg VS 3 deg or lower to avoid detonation...
I was even thinking to possibly order a Progression Distributor, so I could completely customize my curve
