I know that Bob... see post #12... I was doing tune-ups on these cars back in the day, I know the plug specs by heart. I was making a point to the OP.CHAMPION J-11Y as original OEM...
BOB RENTON
BOB RENTON
I didn't realize it until you mentioned it. The AC Delco plug looks like they were installed due to fouling. Some were the AC Delco 41-985's and the others were Autolite 25's. I guess they were battling oil issues as the mota was wore out.Ok but what about the weird Pic of the chevy lookin plug.. is it a motorhome head or is the puc wrong
Rem, both heads say 2991. I could read another stamping that looks like 3462346.What's the cylinder head #? Those are tapered seat plugs, are the heads tapered seat??
A cast number of 3462346? Those should not use a tapered seat plug as pictured, should have standard BB gasketed plugs. Both of those pictured tapered seat plugs were in that motor with those heads?Rem, both heads say 2991. I could read another stamping that looks like 3462346.
Here we goCheck the spark plug holes in the head
So it looks like they had three different plugs in use. All I can say is it seems that they had no idea what they were doing. I have found numerous things on the car that simply made no sense at all. I really appreciate all the help so far gents!A cast number of 3462346? Those should not use a tapered seat plug as pictured, should have standard BB gasketed plugs. Both of those pictured tapered seat plugs were in that motor with those heads?
If not clear, that is not a tapered seat, use the correct stock style/type plugs.Here we go
Got it. I went a head and ordered the NGK XR5's.If not clear, that is not a tapered seat, use the correct stock style/type plugs.
