How about a recap for the S L O W members (Like me) that might consider something like this for my cars ? Was the wire diagram here:
....as simple as it seems? The HEI module just takes coil positive and coil negative as inputs?
Forgive my limited understanding here...I have always had trouble with electrical stuff. The input and output to the ballast resistor must go somewhere though, right?  Where? The diagram at the bottom right shows two wires that intersect the coil positive. I can't make out the writing. Are those the RUN1 and RUN 2 wires ?
I have 3 big block vehicles here with factory type electronic ignition, one 360 with it and one 360 with points.
I've had numerous ECMs and ballast resistors crap out in one of the cars.
There have been pictures posted with a GM HEI module hidden in the back of a factory appearing ECM. I'd be inclined to go that route since it would look sort of like a factory job.
Skimming through this thread and others, I have gleaned that the ballast resistor is no longer needed nor wanted. Geoff suggests the use of one of those coils shaped like a cube. I'd want to package this as close to a factory installation as I could with the coil close to the distributor. I can make brackets.
