Junkyard 5.7 hemi with 22-68% leak down, just rings?
furious70
3:54 AM
Chicagoland
I don't have experience with doing leak down tests and guessing what might be wrong.
JY engine with 22-68% , 68 being just one cylinder. More than rings?
With the leak down tester installed you should be able to hear where the air is leaking from on the cylinder with 68% leakage. Are you looking to purchase this motor or do you own it?
I don't own it and have not seen it in person.
It's a 2017 so was hoping valve seat wouldn't be an issue.
Sounds like I need to ask them to scope it or leave it be.
58% is probably a valve issue, whether bent/burned or just not fully closed... Could be as minor as a bit of carbon was knocked loose when removing the plugs and lodged itself between a valve and valve seat... (probably not)
The other seven cylinders put a teaspoon of oil in each one, spin the motor over & retake the test...
If the engine is cheap enough it's still a good core & if all ya gotta do is repair a valve it might be worth the effort.... Then again I like repairing stuff of I can save some $$$$
You can get your own scope that plugs into your phone, under $20 on Amazon.
I'm not opposed to one needing some work, I'm boosting it anyway so an excuse to go in and change the ring gap helps.
Will be installing a 392 Cam as well. I suppose a new valve isn't bad, if that's it
All used engines are cores to me. This just forces you to freshen it up and it's a bargaining tool to buy it cheaper. 2017 is MDS.
