I don't know anything about your combo to tell you if it is a good fit for you. That is a good price for spring/retainers/chain/cam/ lifters.
The thumper has a wide split on the exhaust and a narrow LSA at 107.  With a racey idle, I have heard it called "dairy queen cam". It sounds mean but doesn't necessarily translate to performance on a BB mopar.  It's origins were more for a small block with short intake runners on a low compression engine that has a choppy performance idle.
 I can tell you that comp cams has had trouble with their lifters so they started coating them with a DLC coating. I don't believe this kit has those. Comp standard lifters are affordable but that is about it.. They are prone to make lifter ticking noise and are pretty average. The better lifters are typically made by HyLift Johnson and sold under other brand names. Usually a higher price comes with it.
Diamond-Like-Carbon: COMP Cams' New Tech For Solid Lifters
