This has been incredible reading. My 69 super bee 440 has screaming tappets right now and I’m not sure what to do. Car runs great, but embarrassing noise. Change the cam? Change the lifters? Change the pushrods? Which parts to use?
You’re in the drivers seat.
There are plenty of cam grinders and lifter suppliers to choose from.
Don’t wanna spend the big bucks(and you’re feeling lucky)?
This cam works great with 1.6 rockers.
Not a Comp fan?
Oregon cam grinders has a version of that cam.
Howard’s has one very close as well.
It has been proven that a cam that is rowdy in a 383 will feel milder in a 440. Also, the power peak goes down. With that stated, I wonder if that Trick Flow cam that runs strong to 6500 in the 440 may peak a few hundred lower in an engine that is 55 cubes bigger.
Summit Racing shows no other roller cams for big blocks. The lifters that Dwayne/PRHeads listed are spendy but if they were actually able to be used again with another cam, that would be great. That usually is the case, right ?
I've never used a bronze gear. I always re-use an existing intermediate shaft gear.And then there's the bronze gear failure. I wouldn't buy a roller because of the available lobe profiles. It just sets you up for a different can of worms. This is all about going to the wrong place because we refuse to make sensible decisions. Blow big money to build the big stroker roller cammed antique and let some pimple faced creep in a supercharged Mustang knock your windshield, with air on. It's all nonsense.
20W-50 | |
Valvoline Race | 0.2 |
Kendall GT-1 | 0.16 |
Shell Truck Guard | 0.15 |
Spectro Golden 4 | 0.15 |
Spectro Golden M.G. | 0.13 |
Valvoline Turbo | 0.13 |
Unocal | 0.12 |
Exxon High Performance | 0.11 |
Valvoline All Climate | 0.11 |
AMSOIL (new) none | |
AMSOIL (old) none | |
Castrol GTX .12 | |
Havoline Formula 3 none | |
Pennzoil GT Perf. none | |
Quaker State Dlx. none | |
Red Line none | |
Valvoline Synthetic | 0.12 |
20W-40 | |
Castrol Multi-Grade | 0.12 |
AMSOIL none | |
Quaker State none | |
15W-50 | |
Mystic JT8 | 0.15 |
Chevron | 0.11 |
Mobil 1 none | |
Red Line none | |
5W-50 | |
Castrol Syntec | 0.1 |
Quaker State Synquest none | |
Pennzoil Performax none | |
5W-40 | |
Havoline none | |
15W-40 | |
Mystic JT8 | 0.15 |
Valvoline All Fleet | 0.15 |
Castrol | 0.14 |
Exxon XD3 | 0.14 |
Exxon XD3 Extra | 0.13 |
Shell Rotella w/XLA | 0.13 |
Chevron Delo 400 none | |
Red Line none | |
10W-30 | |
Valvoline Race (VR-1) | 0.2 |
Exxon Superflo Supreme 133 | 0.13 |
Shell Super 2000 | 0.13 |
Castrol GTX | 0.12 |
Shell Fire and Ice | 0.12 |
Unocal Super | 0.12 |
Valvoline Synthetic . | 0.12 |
Chevron Supreme | 0.11 |
Exxon Superflo Hi Perf 135 | 0.11 |
Mobil 1 none | |
Pennzoil PLZ Turbo none | |
Red Line none | |
Spectro Golden M.G. none | |
Valvoline Turbo .13 | |
5W-30 | |
Chevron Supreme Synt. | 0.12 |
Exxon Superflow HP | 0.11 |
Mystic JT8 | 0.1 |
Mobil 1 none | |
Red Line none | |
Unocal .12 |
I don't know anything about your combo to tell you if it is a good fit for you. That is a good price for spring/retainers/chain/cam/ lifters.Opinions on this setup?
(A local ad i found)
“COMP Cams Thumpr Hydraulic Flat Tappet Cam and Lifter Kits K21-600-5
Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 279/296, Lift .486/.473, Chrysler, Big Block Motors, Kit
(Mfr. #: K21-600-5)
bought two from Summit but only used one, this is a brand new 100% complete cam kit for big block mopar engines such as 383 ci and 440 ci.
Sells for $735.00
Selling for $450.00”
Probably a case of “you get what you pay for” i suppose. Looked like a great dealI don't know anything about your combo to tell you if it is a good fit for you. That is a good price for spring/retainers/chain/cam/ lifters.
The thumper has a wide split on the exhaust and a narrow LSA at 107. With a racey idle, I have heard it called "dairy queen cam". It sounds mean but doesn't necessarily translate to performance on a BB mopar. It's origins were more for a small block with short intake runners on a low compression engine that has a choppy performance idle.
I can tell you that comp cams has had trouble with their lifters so they started coating them with a DLC coating. I don't believe this kit has those. Comp standard lifters are affordable but that is about it.. They are prone to make lifter ticking noise and are pretty average. The better lifters are typically made by HyLift Johnson and sold under other brand names. Usually a higher price comes with it.
Diamond-Like-Carbon: COMP Cams' New Tech For Solid Lifters
In my mind that’s been pretty much SOP for several years.How many of you running high profile FT cams used weaker springs on the initial break-in and then swapped in the recommended springs afterwards?
Maybe I got lucky ?In my mind that’s been pretty much SOP for several years.
I tell my customers, if you don’t do it, and it eats a cam……. It’s just shame on you.
They get the same story about the break in oil.
My engine turned 550 HP and 675 Lb Ft of torque when I ran it on a chassis dyno at the Hot Rod Power Tour (as driven on the tour: full mufflers, air cleaner on, etc.). This was a "fun run" event, so I had no opportunity to tune anything. The horsepower dropped off after about 4900 RPM. Something was going on, and it likely is a fuel delivery problem. With 675 torque, Horsepower should be up over 600. But I haven't had time to diagnose the issue and find that lost HP.I thought he said it was around 500" and made 550 HP or thereabouts.
EVERY TIME. Also, my father-in-law's shop won't even build a flat tappet engine without lifters that direct oil the cam (they do this through a small hole drilled in the bottom or a small groove in the lifter that allows oil to seep through on to the cam).How many of you running high profile FT cams used weaker springs on the initial break-in and then swapped in the recommended springs afterwards?
