cj's mopar
You were spot on the cam grinders I spoke to said that the cores are not able to be ground that tight .You may want to check with a few cam grinders to see if they have a blank that will actually facilitate the lift and lsa you’re proposing.
Roller cores have a fairly small lift/lsa window that they can be used for.
A Low-ish lift and tight lsa roller core for a BBM might be tough to come by.
Best the could do was a 108 with a deg advance at Howard's .
Comp said 108 with a 2 degree advance .
No way getting 104 straight up.
So I decided to go with the Howard's
108 LSA and 4 deg advance ground in.
