65CopCar
Minneapolis - eh? My daughter is in the process of moving there. Need to help her in January.
What's the material? What can it be?
Can this be prevented? Minneapolis is AWFUL. Very dangerous, politically as bad as it gets, absolute toilet.Minneapolis - eh? My daughter is in the process of moving there. Need to help her in January.
www.hobby-machinist.com
Yes the process doesn't sound terribly difficult if I had access to a machine shop.All this entails if? I understand the solution correctly, is reducing the diameter (lathe) of the shank of an existing correct length unthreaded portion of a hex bolt, center drilling it, and then cross drilling the reduced diameter portion intersecting the center hole. Not sure what the best order of above is, and whether SS is needed vs say a plated Grade 8 hex bolt.
Did you mean Earl’s in Australia? Cause that’s all I’m finding using the search terms your provided.Refer to my post #14. If you look at their catalog, you can come up with 5 different ways to fix your minor issue in a clean and professional manor.
Way easier said than done. Have you found a 5/8-20 bolt? I looked at all my sources and did not find one. I would be happy to modify one if he could find one. I found the taps and dies, but no bolt. Only 5/8-18.All this entails if? I understand the solution correctly, is reducing the diameter (lathe) of the shank of an existing correct length unthreaded portion of a hex bolt, center drilling it, and then cross drilling the reduced diameter portion intersecting the center hole. Not sure what the best order of above is, and whether SS is needed vs say a plated Grade 8 hex bolt.
You sir are 100% correct, but then I have not looked. I actually have a 5/8"-18 NA reduced 12 pt head sitting on my desk as I type, and the -20 was overlooked on my part and that was a mistake.Way easier said than done. Have you found a 5/8-20 bolt? I looked at all my sources and did not find one. I would be happy to modify one if he could find one. I found the taps and dies, but no bolt. Only 5/8-18.
It’s hard! Who would have thought?Way easier said than done. Have you found a 5/8-20 bolt? I looked at all my sources and did not find one. I would be happy to modify one if he could find one. I found the taps and dies, but no bolt. Only 5/8-18.
Me? I must have missed that part. I just read your write up on how it could be accomplished. I would be happy with anything that worked.Don't think you ever answered my question. What material do you want or can live with?
