Clutch bell crank bracket location on a 69 Charger
Stucat
3:04 PM
Looking on converting my 69 Charger to a 4 speed. Have all the parts, but need info on locating the clutch bell crank bracket. The engine is not installed so I have plenty of room to work. i found the bracket, but no measurements on location included. Thanks for all the help.
looking on converting
Looking at the inner fender and frame at the access hole there is a notch in the frame that a new weld in bracket tab will fall into if the frame hasn't been modified. Iv'e done a couple of them.
Go hydraulic and forget trying to weld to the frame and hope it all lines up even with the bellhousing
They have their issues too, plus the price.
thanks for all the insight going with the original setup , have all the parts. And yes over a grand for all the parts. Looks like a 10 minute job to put the bracket in. Thanks
Good luck getting it all in. For me a 10 minute job turns into all day and 3 trips to the hardware store. May it go smoother for you. Please post some pics and commentary to help the next member that wishes to do this.
