- 10:41 PM
- Apr 13, 2012
- Granite Bay CA
I'm contemplating a switch to a roller cam in my car and I've wondered about the springs.
How does one determine if a valve spring is still good and what the rate of it is?
A Google search turned up this...
_______________________________________________________________________________________________________________________________________
To test the rate of a valve spring in an engine, you use a specialized tool called a "valve spring tester" which measures the pressure exerted by the spring at different compression heights, allowing you to determine its rate by comparing the applied force to the amount of valve lift; essentially, you remove the spring from the engine, place it in the tester, compress it to specific heights, and record the corresponding pressure readings to calculate the spring rate.
Key points about testing a valve spring:
Important considerations:
- Specialized tool:
A dedicated valve spring tester is required to accurately measure the pressure at different compression heights.
- Spring removal:
Most testing methods involve removing the valve spring from the engine cylinder head.
- Compression measurement:
The tester compresses the spring to specific valve lift heights, while recording the corresponding force exerted.
- Calculation:
The spring rate is calculated by dividing the measured force by the valve lift at that point.
- Manufacturer specifications:
Always compare your measured spring rate to the manufacturer's recommended specifications for your engine and camshaft.
- Installed height:
Ensure you measure the spring rate at the correct installed height, which is the distance between the valve seat and the retainer when the valve is fully closed.
- Coil bind check:
Check for coil bind, which occurs when the spring coils touch each other at full compression, as this can damage the spring.
- ______________________________________________________________________________________________________________________________________
Is this spring checker something that a machine shop usually has?
